Results 1 to 4 of 4
Thread: head liner
    Default head liner
    Does anyone outthere really know how to replace an delaminate head liner in a 740IL/1995......aside from staple and pins.
    Default Hi and welcome here
    yes, I know for sure. I have done several already. See my website below for detailed instructions with pics and special one with sunroof version.
    No big difference for E32 and E38. Just use the online parts catalog and see where the screws, bolts and clips are.
    Or contact this one here
    http://www.bimmer.info/forum/showthread.php?t=13968
    Use the search on top and type in headliner and you will find loads of info and pics.
    The search engine is a wonderful thing to get all the good info out of the archives.
    HeadlinerExpress Guest
    Default Headliner Materail Replacment factory Colors
    Quote Originally Posted by irizarryc
    Heres a place untill January 1, 2006 in which you can Purchase Original BMW Colors in 1/8th inch Material. Holiday Specials are only $99.99 for 4 yards of genuine BMW Stock. Current Colors: heres the link: http://cgi.ebay.com/ebaymotors/ws/eB...RK%3AMESE%3AIT
    Anderson Island, WA
    I fixed mine by using 3m spray high-tack glue.
    I pulled it back and down from the rear of the car and sprayed into the void -- pointing at the TOP of the car. (I let some hit the liner, and it soakd right thru).
    I let it get very tacky, and then slowly wiht my hands, put the liner back up; tucked the "extra" that I ended up with up into the liner and pushed it all back up in the clips at the rear.
    It turned out "ok" -- if I had to do it again; it would turn out much better.
  1. Remove Hood Insulation Liner?
    Last Post: 08-11-2006, 09:12 PM
  2. Which trunk liner do you guys like best?
    By nuclearfusion in forum 5 Series BMW
    Last Post: 06-04-2006, 07:27 AM
  3. E34 Touring Cargo Liner
    By RobK in forum 5 Series BMW
    Last Post: 02-24-2006, 12:38 AM
  4. '92 525IT door panels & hood liner
    By jcos16 in forum 5 Series BMW
    Last Post: 08-26-2005, 03:44 PM
  5. Removing hood liner?
    By franks in forum 5 Series BMW
    Last Post: 03-21-2005, 10:36 AM
