Yep, it should be there, unless someone stole itOriginally Posted by Rob
Hey all,
Is the fuel pump still in the same place on the 1989/1990/1991 525i bmws?
In the boot under the carpet, or is it in a defferent place to that?
Lol, cool.
The reason I ask is because I think it needs removing and cleaning ect. Easy job?
Cleaning? Why do you think that?Originally Posted by Rob
Lack of power. Well so my Dad tells me anyway. I'm not there yet I will be to see the car on Tuesday. But when he did start it after it had been standain for a while it reved to 3rpm ect died and did it again or something..:S. And when he was driving it back to our place it was lacking power
Maybe the pump is ready for replacement, or you have a clogged fuel filter. I would try replacing the filters and doing a regular maintenance first.Originally Posted by Rob
Yeah that's what we're going to do.
I hope it's not the pump that needs replacement as i think they are very expensive
...do recommend you change the fuel filter. There's not much to "clean" in the pump.
Can you give us more information on the problem?
- cold run only?
- does it do it all the time? (repeatable)
- is it a soft loss of power or a hard cutout or a sputter?
- you mention the car had been standing - for how long?
- does the car start idle and generally run smoothly?
Bellevue WA
86 Porsche 951 - Track Toy
Originally Posted by Jeff N.
I found this in a search query. I've been exhibiting similar symptoms lately. Started it tonight with the temp ~ 30 F and a wind chill of too damn much. started alright, idle rough, but Ive heard thats normal for an m30. Backed the car out of the driveway and put it into D, and nothing. Pushing on accelerator make the idle even worse, sputtering and 3/4 dying out, no power whatsoever. Since auto tranny, car moves a bit on its own, and finally started going normally after 2 or 3 min of .5mph crawling. Get to the end of the street, stop, and then nothing again. I would've been better off getting out and pushing the car home, woulda been faster. Ideas? (89 535ia, 124,500) I'll check codes tomorrow, to see if that helps
The CEL light is on and throwing the 1215 code and 1224 code... I dunno squat about either of em. Uh oh
