Forgot to mention -- it's a 92 735i (e32)
My steering sometimes, at low speeds, gets very hard (like the power steering pump is out).
It's happened twice in teh past month.
I've been giving advice that it's either the servotronic unit (under the dash?) or the sending unit at the gearbox.
Does anyone have any idea what it more likely is? Or should I change both?
-josh
First check basic things, belt tention and enough oil? Replaced the filter ever?
If all this has been done alredy,
see this
http://www.bimmerboard.com/forums/posts/52193/
Belt is fine.Originally Posted by shogun
Fluid level is fine.
and (drum roll please) What filter?
Thanks for the link -- I'll check into the unit...
-josh
http://www.autohausaz.com/search/pro...aulic%20Filter
Or check which power steering you have and which filter here, and you can see where
http://www.realoem.com/bmw/select.do...938848d4d39ea1
Thanks. I looked at the oem site; but didn't see a filter for the power steering pump... I'll look in my manual & look on the car to determine if I have "For models with Bellino and Cie system" or not.Originally Posted by shogun
Thank you for the links & help!
-josh
Let us have the last 7 digits /letters of your VIN, then we can check it.
Dang.. thanks for all the help! I surely do appreciate it.Originally Posted by shogun
DB71885
-josh
