-inspection II
-maybe replace rear rotors
-wash/wax/detail
-trunk net?
-childseat tether anchor (bought it, just need to install)
-align sunroof lid
-drive and enjoy!
:dance: I'm in the process of that "To Do" list for things I need to do to my car for this year. Actually it seems like a wish list, but some of those things are things I need to do. Anybody have those kind of things they need to do to their car? I have a little sample if you are interested...
-Replace Heater Core
-Replace Tires
-Replace Thrust Arms
-Replace Output Shaft Seal (Warranty)
-Get Mounting Bracket for CD player
-Replace Shocks for Hood
-Find Rattle in Rear. (Something Plastic... Driving me NUTS!)
-Flush Brake Lines and Replace Lines With Stainless Steel Brake Lines!
-Replace Bulbs Behind Temp. Selectors.
-Fix Lose Wire to OBC.
-Fix Rear Driver's Side Window. (Needs to go up and down, broken part)
-Replace Rubber Gaskets on Master Brake Cylinder (Upper intake)
-Fix Power Steering leak (Probably Hose)
Then...
-Get Sachs Kit.
-Get Engine and Transmission Performance Chips.
-Get Strut Braces.
-Get an Aftermarket Sub and Amp.
-Upgrade Brake Discs.
-Aftermarket Exhaust System.
-Repaint
Then...
-Supercharger
-NOS
-Twin Turbo Chargers
-Innercooler
-Lasers
-GPS & Nav. Systems
-Tub Kit
-Drag Bar
-Playboy Model For Photo Opts.
-More Lasers...
-Blinking Lights In Front Like Night Rider's Car...
-Smart Computer with Animated Voice Coming From Ash Tray
-Lighted Ground Effects
-Parachute in Trunk
-Seat Massagers with Optional Heat Settings.
-Fuzzy Dice (Blue to match my car)
-Neon License Plate Holder
-Lighted Shifter
-Huge Aluminum Rear Wing
-Even More Lasers...
-James Bond Oil Slick System
-James Bond Rockets
-James Bond "Laser" (Is that too many lasers?)
-Water Wings for swimming.
-Fancy Racing Shoes
-Fancy Racing Pants
-Auto Drive Option (in case I get sleepy)
-Fax Machine
-Copier
-Big Mac Sandwich
-Fuzzy Dice that you can hang on those hooks in the back seat, both sides!
... I think that's about all, maybe I need more lasers?
-Eric
-inspection II
-wash/wax/detail
-trunk net?
-align sunroof lid
-drive and enjoy!
Bill B.
95 525i
I've got a 66' tbird sitting out front making rust... I'm planning on pulling the 390 that it has in it now, and buying a Fiberfab Avenger or Azten (Ford GT40 replicars) in bad condition from ebay, and making a hotrod rear engine monster.
For the 535i, everything just sort of works right now so we'll see how it ends up in a few months. I may get my wheels reconditioned, since they're pitting, and I need new pads and rotors so I may go for a 750il brake kit up front with 540 calipers in the back. Oh, and I'm also considering a UUC short shift kit and maybe an m5 clutch.
Do you have a Pioneer or Alpine Cd Changer? I have three different Pionner mounting brackets I'd be willing to part with.
I've got a '59 Galaxie that needs a tranny - one of my spring/summer car items is to find a new/used/rebuilt tranny and swap it in. Currently has a 3 speed autobox on a big block 352 - same block as your 390..... Might bolt right up? :trooper: :trooper:Originally Posted by AllanS
--Micah
I'm not sure of the transmission's condition- it's a 3 speed auto for sure, but the car hasn't been started in over 10 years. Everything under the body is in surprisingly good condition though, and I suspect the tranny would be fine after a rebuild. I started to pull the engine last summer, but lost interest, and I never encountered any real rust under the hood.
If you want, give me a holler and come look at it- you can just haul it off for free, since I have no use for it.
I will keep this in mind. Probably won't be digging into that project until this place thaaws out, but I'd bet you're in a similar position....Originally Posted by AllanS
Thanks!
yep, seeing as it'll be under 12" of snow come tomorrow afternoon, if the weather reports are correct
Well, my list is something like:
Drive axles on '95 VW
3 Electrical issues on '95 VW
Fuel pump on E34
Reset SI lights on E34
Trunk lock actuator for E34
Keyless entry for E34
Then the 'project cars'
Get '65 Corvair convertible running well enough to drive to storage
Get '66 Corvair 4-door out of storage and finish body work
Paint '66 4-door!!
If I make it this far this summer, I'll be quite happy. My wife won't be, but I will be.
Pioneer! It's the thin one! E-mail me directly to let me know about price.
-Eric
