Results 1 to 10 of 11
Thread: F- Your AUDI S4!!!
    PA
    Default F$&# You AUDI S4!!!
    Yeah so when building the intake track for my supercharger (charged air from blower to the throttle body..) i used an Audi S4 biturbo upper intake boot. Reason being that it was molded the shape I needed, it had a built in integrated diverter valve vein and was reinforced.
    All is true, EXCEPT, it's NOT reinforced silicone. It's shitty rubber. The Biturbos are making like 8psi stock between two turbos... I guess the load isn't as great as 9 psi supercharged. The hose burst right at the joint. I coated it in silicone so i could limp it back to school sunday night. It got me to school (huge huge huge vacuum adn boost leak). Threw CEL (maf sensor misread, 1215) all the way out, got like 8mpg for 60 miles because of this damned boot. So yeah, that's right, F- You AUDI S4!
    I made a new one out of MIG welded steel. I will post pics tomorrow. Works much better, and MUCH stronger!
    Aug 2005
    Newton, MA
    Damn, i wonder what BMW would have used in a situation like that, but then again - naturally aspirated engines... no forced induction
    Gainesville, FL
    I can't wait to see the steel one. Good job flipping off the boot, by the way
    Nov 2004
    Middle England
    Obvious difference to me is that it was designed to be 'sucked through' on a bi-turbo ... your words read as if you are using it to 'blow through' with a super .. so failure probably predictable ?
    '90 535iSE Auto (AE+EAT) 123k miles
    '86 F288 69k miles
    '06('89)- PGE 2.0DOHC Turbo
    '03 A160LE 19k miles
    1914 Stellite E2A (no odometer!)
    (+ others I daren't mention here)
    www.pyghtle.com
    PA
    Quote Originally Posted by zygoteer
    ... no. Its a boost tube on both my car and an S4. Hence the diverter valve output.
    Wichita, KS
    Seems like I remember from my Audi days that that's one of the first things they change out, I guess you know why. I think there's far better aftermarket ones.
    Matt J.
    '95 540/6- Jim C. chip, Bilsteins, B&B, For Sale!
    -Sold
    www.wichitabmw.com
    PA
    Yeah, they're $129 for just that hose from Samco, the full kit is over $400
    Never saw red spooge like that...you been eating a lot of beets or something?
    9psi isn't much for a rubber hose.
    Was it second-hand? Given that it failed at the clamp-zone, it could have blown due to heat/age or more likely a pre-existing injury (being pulled off at a wrecker).
    Alternatively, your charger might create larger peak pressures than the stock A4 setup. These wouldn't be necessarily reported on your gauge... I imagine it irons out the shorter peaks efficiently.
    Long Beach, CA
    Oh well, you'll be much better off with your newer, stronger part.
  1. OT: Audi A4
    Last Post: 06-19-2007, 06:07 PM
  2. Audi 250 km/h crash
    By krzysiom5 in forum 5 Series BMW
    Last Post: 06-09-2007, 06:44 PM
  3. ot: Audi 90
    Last Post: 06-09-2007, 01:27 AM
  4. Wadded up Audi...
    Last Post: 03-27-2004, 12:10 PM
