Originally Posted by
BobHarris
Check that the glow plug relay is actualy working with a multi meter.
Listen for it turning off, the light may go out prematurely (sp?) so you try to start before the glow plugs are hot. (have only seen this happen on Fords and Vauxhalls, but may still be relevant).
Hi Bob,
I am sure it is - the interior lights go dimmer when switching on, the glow plug light goes out after about 10 seconds and the interior light stays dimmer and brightens after about 20 seconds (not timed it) so I assume that is the plugs turning off - each glowplug takes some 17 amps times six is approx 100 amps total - quite a relay ! - do you know where it is ?
Nick
