Results 1 to 4 of 4
Thread: HUB CENTRIC RING"S
    Apr 2005
    new zealand
    Default HUB CENTRIC RING"S
    HI guy's I need to get some Hhub centre ring's made up is 72.5mm(inner) an 74mm(outer) correct .
    Jun 2005
    Davis, CA
    Default The Tire Rack carries them and I am told Discount >>
    Tire also has them. Tire Racks are metal and I am told Discount Tires are plastic. Check on mye28.com for the part number, I think it is A104 but better be sure. I got mine from Tire Rack and they gave me a hard time about how could they be sure it was the right part etc since I wasn't buying wheels. In the end I got them for ~20 shipped.
    Quote Originally Posted by montsta56 nz
    Craig in Davis
    89 535i auto to manual conversion
    Delphin-Metallic/Black leather 296k
    83 533i 5 speed Alpinweiss/Cardinal Red leather 236k
    Wellington,New Zealand
    72.5mm is the correct dia for your e 34 hub but the outer dia depends on the id of the actual wheel hub.74mm is the id for a genuine e 39 wheel and many replicas.Any tire place should be able to get you some,but it might pay to get accurate measurements first
    Feb 2005
    Richmond, TX
    I got mine at Discount Tire and they are metal. I'm not sure how you could make decent plastic ones that thin.
    1988 M3 - Track rat
    1989 325iC
    1995 530iM
    2000 323iT - UUC BBK, PSS9 Coilovers
    2005 GMC HD Crew
  1. hub centric rings
    By stx133 in forum 5 Series BMW
    Last Post: 10-23-2009, 03:27 AM
  2. Hub Centric ring quality. Does it fit?
    Last Post: 09-17-2008, 07:06 AM
  3. Hub Centric Ring Replacement
    Last Post: 03-25-2008, 07:20 AM
  4. Hub centric rings
    By E34 530 in forum 5 Series BMW
    Last Post: 11-03-2005, 08:44 PM
  5. Hub-centric Ring Question
    By JR'Z 525 in forum 5 Series BMW
    Last Post: 02-13-2004, 01:42 PM
