Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: It thinks the key is in ignition, won't start - HELP!!
    That is the antenna ring and has to be removed in order to get the cylinder out. They tend to snap or shatter on removal.
    The detent is almost certainly broken (antitheft feature commonly messed up by hamfisted starting); the car will need a new lock cylinder (less than $100 at the dealer). It can be tough to remove, sometimes taking hours. We did one a few months ago that was so bad that the entire assembly had to be replaced.
    best, whit
    Nov 2004
    Northern Virginia
    Default Where's my sledgehammer??
    I'm trying to remain hopeful, but not much progress has been made...... Thanks for the tip about the antenna ring, Lowell, I got that off without breaking anything (at least that part went well!), but still haven't gotten the lock cylinder to budge.
    Can someone who's done this before tell me how much resistance I should expect when inserting the wire? There are two positions at roughly 60- and 65-degrees that I can slide the wire in rather deep. At 60 it slides real easy, there's more resistance at 65, but in between those two I can't push it in at all. Does that make any sense?
    Also, the wheel is locked - does that help define the situation any more?
    Today's redeeming quality is that my girlfriend brought over a donut for me this morning, knowing I couldn't drive to get my favorite weekend snack on my own
    Nov 2004
    Northern Virginia
    AND I can't get rid of the PPPP code when I reconnect the battery.....
    Australia
    what is that PPPP code anyway?? I always have it on OBC when reconnecting the battery.
    Long Beach, CA
    Quote Originally Posted by dacoyote
    Or... you can be like me... and have a push button start....
    That's not going to do him much good now.
    Long Beach, CA
    Quote Originally Posted by romus
    Just need to set the clock and date.
    Australia
    hey just a thought - are u using the master key when u do the 60 degree turn before u stick the wire in???
  1. Car thinks door is open
    By bimmerboy in forum 5 Series BMW
    Last Post: 10-28-2008, 02:52 PM
  2. Ignition won't go to "start" position?
    Last Post: 12-18-2007, 06:13 AM
  3. Ignition fuse blows after each start up.
    By mossyoaks in forum 5 Series BMW
    Last Post: 05-17-2006, 12:38 AM
  4. My car thinks it's really, really cold outside
    By Mitch90535im in forum 5 Series BMW
    Last Post: 05-01-2006, 02:59 PM
  5. key won't rotate in ignition switch or start car
    Last Post: 03-12-2005, 10:59 PM
