Results 1 to 10 of 14
Thread: If I unplug the coolant level sensor and nothing happens, its a short ??
    Nashville, TN
    Default If I unplug the coolant level sensor and nothing happens, its a short ??
    Given my latest cooling system woes - I have discovered that the low coolant warning is not firing upp. Sensor is free - but if I unplug it nothing happens.
    Any tips from m30 owners on where the wires get messed up ?
    D.-
    Derek A.
    90 535i 5 Speed - Style 5 17"
    fuse?
    Nov 2004
    Split, Croatia
    Quote Originally Posted by Derek A.
    I doubt it's a short - in 99% of the cases the problem is the corroded/oxidized plug/connector and it results in constant bitching about coolant level. You should check the fuse as Jeff suggested and then try cleaning/swapping the sensor.
    Nashville, TN
    I am not getting any bitching about the coolant level - that is the problem. If I udnerstand correctly the switch is closed no messsage, once it opens you get a message. So if I unplug the sensor - I should get a warning...right ??
    Is there a special fuse for this ?
    Derek A.
    Mar 2004
    MASS
    Default Try shorting the plug
    The wiring might be opposite of what you state where the sensor is always open and closes when when the level is low. If you short it the plug and the low coolant message comes on then the sensor is bad.
    Mar 2004
    MASS
    The wiring might be opposite of what you state where the sensor is always open and closes when when the level is low. If you short the plug and the low coolant message comes on then the sensor is bad.
    Mar 2004
    Correct. According to ETM page 6200.0-11 the level switch opens on low level. Disconnecting level switch will have the same effect and should turn on warning msg. These devices are intentionally wired this way to check for both low level and wiring problems. It's a type of supervised circuitry.
    Check control module may be bad or disabled. Fuses 1 and 20 power CC module. Can you force any other check control warnings? open door, lights on, low washer fluid, etc?
    Paul Shovestul
    Long Beach, CA
    Quote Originally Posted by Bellicose Right Winger
    Paul Shovestul
    That Coolant Level Sensor is a PITA!
    Nashville, TN
    Quote Originally Posted by uscharalph
    Its right in the top of the resvoir - takes 2 secondds to pull out. Its not an m50 which has them buried in the radiator.
    Derek A.
    Default Follow Paul's advise, if you get no messages from CCM, ...
    then check CCM fuses F1 and F20 (but bad fuses should reveal other symptoms, so I doubt it).
    The wire coming from CCM is the Brown/White one, when the sensor is unplugged, this wire should have some voltage, if not, either the CCM metering resistor (inside CCM from pin 4) is bad, or the wire is shorted to ground between CCM and the sensor connector, remove CCM and check continuity to ground to debug. It is a straight wire from CCM connector to level sensor.
    Javier
  1. Coolant level after new sensor and MPG
    By JetMech in forum 5 Series BMW
    Last Post: 03-04-2009, 11:00 PM
  2. coolant level sensor
    By robert g in forum 5 Series BMW
    Last Post: 11-16-2007, 04:30 AM
  3. Coolant level sensor etc etc.
    Last Post: 01-06-2006, 12:17 PM
  4. coolant sensor - could I short it out ?
    By donberry in forum 5 Series BMW
    Last Post: 02-28-2005, 08:52 AM
  5. coolant level sensor
    By riot in forum 5 Series BMW
    Last Post: 12-05-2004, 10:15 PM
