Results 1 to 5 of 5
Thread: Wiper control
    Apr 2005
    Canada
    Default Wiper control
    What control the wiper speed on a E34 535i 89 ?
    I have a strange problem, the first continous speed position now give me an intermittent wiper, so i now have 2 positions with entermittent wiper mode (a bit longer delay with this new intermittent position) and still have the high speed continous mode on the third position as usual.
    Any clue as what may be the cause of this and how to fix that problem ?
    Thanks Claude
    near Portsmouth, England
    I assume (I know ) that you are travelling at over about 10 mph when you try the wipers? As they are supposed to go intermittent at standstill.
    Other than that I'm afraid I can't be of any use.
    All the best
    Bob
    Default May be the General Module is missing the ...
    speed signal from the instrument cluster, and believes the car is not moving. The same signal is used for Speed monitoring at OBC, Radio, Cruise Control, A/C and DME
    Javier
    Apr 2005
    Canada
    Quote Originally Posted by Javier
    Javier
    Make sens ! I actually have an intermittent cluster and after your comment i check the wiper operation again to realize that my wiper problem occur only when the cluster is dead (no speed info), when the cluster come alive (speed info came back) the wiper work properly.
    In other word, when i'll have fix my cluster problem i'll also get rid of my wiper's one.
    Nah, the cluster is probably fine. The car likely needs a speedo sensor. Common problem.
    Replace the speedo sensor before you waste any time on the dash module.
    best, whit
  1. Wiper Arm Q
    Last Post: 08-23-2009, 05:26 AM
  2. WTB 91+ Wiper Arm!!
    Last Post: 10-09-2007, 12:47 AM
  3. intermittant wiper and no cruise control???
    By bullyd in forum 5 Series BMW
    Last Post: 05-29-2006, 02:18 AM
  4. Replies: 4
    Last Post: 01-04-2006, 02:11 PM
  5. need to locate windscreen wiper control relay
    By xxdeanoxx in forum 5 Series BMW
    Last Post: 09-20-2004, 05:33 AM
