dude that just sux...could be worse though!
Id say try to get to as much of the exposed wiring and clean/dry it off. If its water in the main runs then you have cracked wire insulation which I kinda doubt. Your main window switches need to be removed in the center along with the hazard switch, cleaned and dried. You probably have a couple areas that are wet, take one at a time.
Have fun!
