Results 1 to 10 of 10
Thread: 735i light question
    Aug 2004
    Default 735i light question
    my right side parking lights don't work . the light ball is ok signal works on this side but for some reason back and front parking lights don't work when i turn it on. right side is ok
    thx
    Hi ve39,
    basically the E32 has the same probs with that as the E34. So first of all, check the fuses, change them even if they seem to be o.k.
    Use a mutlimeter and check if there is power on the light cables at the bulb sicket.
    Next thing -if that does not bring any result-as usual: soldering LKM, mustard relay.
    Also check if the wire connections to the bulb holders are corroded. Sometimes they look nice, but underneath the plastic the core is compeltely oxydized.
    Aug 2004
    thx alot man i will check it out this week
    i'v got this car last week so yeah i guess i should check the fuses first
    Aug 2004
    i still havn't checked it but i noticed that in the mornings lights work but just when the car is cold. i'm guessing it's some broken wire then
    Maybe you also change the bulbs to new ones, or just switch from the good one to the bad side if the probmoves to the other side.
    Check also the contact surface bulb/bulb holder, might be oxydized too. I found a lot of oxydation in the rear licence plate lights. Did not work, alram, cleaned the whole thing with emery paper and it works now w/o prob.
    Aug 2004
    found something here about my problem, will try it this weekend
    http://www.homeofsbc.com/Fixes/Light/light.html
    I just noticed that you wrote:
    "that in the mornings lights work but just when the car is cold"
    I once read on the German board about this. They installed new bulbs and resoldered the mustard relay and the LKM and then it worked.
    Best repair for this is on my page on the link to E32fixes.com.
    Good pics and additonal LKM fix.
    Use a large magnifying glass if possible when doing that in order to detect all points to be resoldered.
    Good Luck
    Aug 2004
    damn looks 2 complicated are those expencive to buy ?
    Ohh, yes, quite expensive.
    Especially the LKM. Check the prices at the online vendors, such as bavauto.com or
    autohausaz.com
    and I am sure after seeing the prices you will find resoldering not that complicated anymore ;-)
    Aug 2004
    Well winter came it became darker and i desited to try and fix this problem.
    i did not have Soldering gun/iron, Solder or Solder sucker. I have tryed heating a knife on the stove and use it as solder gun, that did not work well so in stead of melting and unmelting solder on master relay i just pushed it all hard with the knife for them to have a connection again. I did not think it would work but it works my lights are working.
  1. LCD Panel Light Question
    By filmy540i/6 in forum 5 Series BMW
    Last Post: 03-18-2009, 11:14 AM
  2. Easy question about abs light
    By simonslw in forum 5 Series BMW
    Last Post: 03-02-2008, 02:56 PM
  3. SRS light question
    By gmannino in forum 5 Series BMW
    Last Post: 01-15-2007, 02:55 AM
  4. another fog light delete question
    By angrypancake in forum 5 Series BMW
    Last Post: 01-23-2006, 09:10 PM
  5. Fog Light question
    By spddmn713 in forum 5 Series BMW
    Last Post: 01-14-2005, 01:10 AM
