Page 1 of 7 123 ... LastLast
Results 1 to 10 of 69
Thread: Fuel pump/starting problem for the electricians and experts
    Sep 2005
    MI
    Default Fuel pump/starting problem for the electricians and experts
    This is my first post here but I’ve been searching for an answer to this problem for at least 1 week, 2 hours/day all over the internet. Other people have had the problem but there are no answers . . . are you ready?
    We just bought a 1994 525i with 191,000, in great shape, meticulously maintained by an engineer. My wife drives 15 minutes to church and it sits for about 15 minutes. She then tries to start it again and it turns over (sounds like good compression) but it doesn’t fire up. A quick diagnosis: no fuel pump noise, bad fuel pump. I buy a used fuel pump off eBay while I’m waiting for my dad to loan me his volt meter. The volt meter says no power is going to the pump (fuse 23). Because I don’t know which relay is for the fuel pump I checked every relay under the hood and only 2 refuse to snap: one large relay with about 8 pins in the driver side fuse box (across from the crash alarm relay, separated by the LKM I think), and a five pin relay by the ECU – yes, the DME or the main relay. I buy a new DME and still no power to the fuel pump. I finally find the fuel pump relay by testing for resistance to the hot side of fuel pump fuse, and replace that relay (even though it was snapping). Still nothing.
    Jumped the fuel pump relay with fuse 23 in its proper place and guess what I hear . . . the fuel pump in the trunk and the injectors (I think) in the engine compartment) which makes sense according to the wiring diagrams (the fuel pump relay runs both). All the contacts in the relay plug are working fine: 30 is hot all the time, 87 grounds out after going through fuse 23, the fuel pump, and the injectors. When the key is turned, 86 is hot and is sending 12 volts through contact 85 which grounds out without a problem. Still, with the relay in place no power goes to the fuse.
    When I turn the engine to try to start the car *and* jump the relay, the pump runs fine but the engine still won’t start. I don’t smell a lot of gas coming out of the exhaust but I’m afraid I will flood the engine if I keep running the pump/injectors w/o the relay.
    This “power-to-the-relay-no-power-to-the-fuse-unless-I-jump-it” is giving me nightmares. I just doesn’t make any sense.
    There are no error codes (when I read the codes, the light blinks for .5 sec, off for 2.5, on for 2.5 and off for 2.5 in a continuous cycle).
    I’ve heard it could be the crankshaft position sensor but I also heard that would give me a code.
    Any ideas? What is that big relay opposite the crash alarm relay? Tonight I will test the sensor if I can find it and check for spark and fuel pressure. I have TIS disks coming in the mail. I need an answer before I run out of money. Any help is much appreciated.
    Job 14:1 Man born of woman is of few days and full of trouble.
    az
    Default Electrical Geniuss Wanted
    Good details in your post, you will have to wait for the electrical department to come back from lunch...lol. Bet you get an answer here.
    Lake orion huh? Thats just east of me.
    Benneton (United Colors of)
    did you ever replace the DME relay in all of this?
    Sep 2005
    MI
    Default Replaced DME
    yes, I replaced the DME with a new unit $17, fuel pump relay was $15.
    I also replaced the fuse in my dad's volt meter when measuring the amps going through the relay . . . there are at least five amps moving through just fine
    Bavarian BMW in Utica/Shelby Township want $114 to look at it but I have to tow it there.
    The crankshaft sensor will be $95 if I need it.
    az
    Aug 2004
    Pittsburgh, PA
    Fuel check valve.
    http://www.bimmer.info/forum/showthread.php?t=14388
    It fixed the no start problem with my car. The dealer said it would not work on my car but what the hell do they know. Easy, cheap and fast fix.
    Sep 2005
    MI
    Default check valve?
    I can try it but I don't have a 'hard [when] hot' start problem. It's 'no start' and it's electrical I think. But to test my theory, if I take off the fuel line before the injectors, and there is gas and pressure, it is not the check valve right? And if I jump the pump relay or fuse and gas is flowing that means there are no clogs.
    I will be extremely careful to direct all the extra gas into a bottle and keep the garage ventilated.
    az
    West Palm Beach, South Florida
    Default Electrical Guiness? :)
    I read somewhere a writeup on checking fuel pressure by doing that, and the guy ran the fuel into a 2 liter bottle. If you've ever sprayed a part with throttle body cleaner (or brake cleaner) and had the excess run into a plastic cup, you'll see why this makes me wary. Not saying its dangerous, but I think petroleum based products don't like plastic so much. In any event, mabye drain the gas into a glass bottle when you check for fuel?
    Now, as far as your electrical problem...
    I don't like the way this sounds. I might be misinterpreting what you're saying, but nothing at 12V should short directly to ground.
    You said you replaced the DME for $17, I assume you mean the DME relay. I've never really had a need to run a test to see if the DME had power by checking voltage, I guess if you're checking current running to it that would tell you (if you have the multimeter connected correctly). I would check for spark by pulling a spark plug. If the DME doesn't have power (or doesn't have all of its info, i.e. no cps, etc) it won't fire the plugs and injectors, right? Someone else can back me up or refute that one.
    I would think that if the CPS were bad, or another sensor was keeping the DME from wanting the engine to run, you would get a check engine light. You never know though, the PO could have removed the bulb.
    Have a check at the fuel flow rate, but I don't think thats it. If you look at the procedure for replacing the fuel filter, it says "pull the fuel pump fuse and let the car run till it stalls". You would think that if the system has pressure when you shut the engine off, and then go to restart it (without the fuel pump turning on), it should at least run and then die (not sure on that one either).
    Also, check for spark and let us know whats up with that. Thats about the extent of my electrical expertise I can give you for now.
    Sep 2005
    MI
    The contacts I was referencing were specifically for the fuel pump relay (although the DME relay plug tests correctly as well, the only difference there is where the DME relay contacts 87 go, there are 2 87s, five prongs in all)
    on the fuel pump relay, contact 86 comes from the DME relay or some type of switch (see here http://www.carsoft.ru/avtorepair/bmw....10/index.html) and 85 goes to the actual DME control unit. I just tested that contact 85 was grounded (I assume after it goes through the DME control unit.
    The check engine light is definitely working but I may be reading the codes incorrectly, please see my first post. Also, when I press the reset button under the tach and trun the key and then release the button one line says "CODE.NR 0000" which I assume means no codes??
    Tonight I will revert to the troubleshooting I use on my 1980 johne deere snowmobile but I fear the problem is deep inside the electronics.
    az
    Cardiff UK
    Sounds like you should check the crank position sensor.
    I currently have the same problem with my 520i, it was intermitent but now will not fire, cranks fine, fuel pump runs etc.
    I've followed the cps cable from the sensor to up near the thermostat housing and behind the oil filter housing but then the cable disappears beneath the inlet manifold / near the alternator and so far I can't locate the connector. Perhaps it's easier from underneath the car?? Or maybe it's easier to check the signal at the ECU plug? anyone know the pin number?
    Aug 2004
    Pittsburgh, PA
    Does it start when sitting overnight?
  1. new fuel pump problem, help
    By johngreenedc in forum 5 Series BMW
    Last Post: 11-14-2007, 10:39 AM
  2. Fuel pump/starting problem for the electricians and experts
    By azale in forum Engine & Drivetrain
    Last Post: 10-11-2005, 09:55 AM
  3. Trouble Starting - but runs perfect. Fuel pump?
    By sbraun14 in forum 7 Series BMW
    Last Post: 03-26-2005, 01:16 AM
  4. e34 fuel pump fuse problem
    By jesse in forum 5 Series BMW
    Last Post: 03-10-2005, 04:12 PM
  5. Need Info On Possible Electric Fuel Pump Problem
    By Pwr2spare in forum 5 Series BMW
    Last Post: 01-31-2005, 10:06 AM
