Results 1 to 3 of 3
Thread: intermittent odometer display
    Wellington,New Zealand
    Default intermittent odometer display
    bulbs in cluster need replacing?????
    Gone but not forgotten
    May as well start by replacing the bulbs. Cheap and easy.
    Jan 2005
    Reno, NV
    Just had that happen to me. Replaced bulb, now all is OK. I did it without unplugging anything, just turning the cluster in the dasha nd using long needle nose pliers (but not before trying to see what bulb it was and unplugging the wires only to set the SRS light a flashing)...... It is a 1.5w so you don't do the same, OR REMEMBER TO DISCONNECT THE BATTERY BEFORE DOING ANYTHING.
    Stephen
  1. E30 Odometer Gears
    By mikell in forum 3 Series BMW
    Last Post: 01-09-2011, 05:15 PM
  2. :: Odometer tamper dot
    By Macv in forum 5 Series BMW
    Last Post: 03-30-2008, 04:35 PM
  3. Trip Odometer Won't Zero Out?
    By stilljester in forum 5 Series BMW
    Last Post: 12-16-2006, 05:03 PM
  4. Intermittent Odometer reset problems
    By Chris'91'525i in forum 5 Series BMW
    Last Post: 09-08-2006, 09:49 PM
  5. stuck odometer
    By jiminEcricket in forum 5 Series BMW
    Last Post: 07-25-2004, 11:36 AM
