Results 1 to 4 of 4
Thread: Buying Foglight bulb
    Default Buying Foglight bulb
    Where can I buy these? The littlw bulb for the foglight? I think it is an osram? Do the local stores such as auto zone and pep boys have them or just the stealer and the foreign parts stores? thanks.
    Long Beach, CA
    Quote Originally Posted by nealf
    I believe I got one at Pep Boys. My best advice is to take the bulb and your owner's manual into the store to ensure you get the correct bulb. Compare the new bulb to the old one before you buy it.
    Elm Grove Farm, NC
    Yes, Pep Boys, autozone, etc should have them- I've even seen them at WalMart (!!). Take a look at the silver base of the bulb BEFORE you buy a new one, it should have the info you need to make sure you get the correct bulb. You will see the name of the bulb maker (Osram, sylvania, etc) a watt rating (something like 55w) and the generic bulb type (in this case- I think it should be "H1"). The important part is the "H1"- as long as you get a new bulb with this number, you're all set.
    Bret.
    Sep 2005
    Perth, Western Australia
    I've heard that using different brand bulbs may result in fault messages on the dash, due to different resistance values. I myself got error messages regarding brakes, licence and low beam when the bulbs had turned a little black (but still working). Replaced the lot with new Osram, and no fault reports since. Happy it wasn't the light control module.
    Robert, Western Australia
    '94 540A, Eibach, 17" replicas, 151.000k
  1. Parking light bulb = signal light bulb?
    By bigtisas in forum 5 Series BMW
    Last Post: 11-06-2006, 11:52 PM
  2. Replies: 11
    Last Post: 10-04-2006, 06:35 AM
  3. foglight bulb replacement E32
    Last Post: 04-22-2006, 02:55 PM
  4. e34 foglight bulb
    By meinE34 in forum 5 Series BMW
    Last Post: 08-26-2004, 09:01 PM
  5. Replies: 7
    Last Post: 03-10-2004, 09:30 PM
