Page 1 of 3 123 LastLast
Results 1 to 10 of 26
Thread: Newbee needs help?
    Jul 2005
    Default Newbee needs help?
    Hello,
    I'm new to the site and am looking for a little advice if you all don't mind. I have the opportunity to buy a 1994 530i with 50K miles. The vehicle has been in the garage since day one and has never seen snow. The car is mint inside and out.
    However, the owner has stated that the oil has been changed only twice and the brakes pads haven't been replaced yet.
    The car sounds great and rides perfectly.
    Any reason to be concerned about the limited maintenance?
    Thanks in advance.
    dspdante
    Default People are not that dumb...
    Perhaps the owner is mistaken? That would indicate a high level of dealer slackness and owner stupidity: Oil should be changed every 6 months, as well as the first change at 500 miles or so. If this is the way it is, the engine will be worn and clogged. Perhaps it went unused for a long period of time? If so was the oil changed immediately after that?
    If you do decide to buy it, do the oil change before driving it home. If it's on eBay, give it a miss, there will be something they are not telling you. If it is a genuine sale be very wary. GP
    Jul 2005
    Default thanks for the advice
    Quote Originally Posted by genphreak
    Thanks for the advice, I thought it sounded strange as well. Changing oil every 3K to 5K is standard operating procedure.
    How can I be sure that there isn't permanent damage to the engine? Can a diagnosis be made?
    Jul 2005
    Long Beach, CA
    Quote Originally Posted by dspdante
    Hello,
    Thanks in advance.
    dspdante
    Have it evaluated by an knowledgeable mechanic before you buy it.
    Mar 2004
    So Cal
    Default nikasil
    Hello,
    Thanks in advance.
    dspdante
    Make sure you check to see if the nikasil block has been swapped out.
    Greg Mendoza
    May 2005
    I'd pass on that. It's probably a Nikasil block and with the very long change interval you're just asking for trouble. Now if it's priced well below market, that's another matter.
    Jul 2005
    So Nikasil is a bad thing. Can I research if it's a Nikasil engine block by using the VIN#?
    Jun 2005
    Cleveland, OH
    Yes
    I think Link tells you what sort of block it has.
    Work is blocked
    -Charles
    I miss my e34
    you will need to get the engine casting numbers off the block whish is straight up infront of the starter. Nikasil isnt necessarily a bad thing or something to run from these days. If it starts thats half a sign its good, if it idles rough it could be a ton of other things causing that. The only way to make sure its good is a leak down test. do a search for nikasil on this forum.
  1. newbee log time BMW owner
    By MargaritaMark in forum 5 Series BMW
    Last Post: 10-13-2006, 06:59 PM
  2. newbee needs help with belts
    By rvives in forum 5 Series BMW
    Last Post: 10-30-2004, 10:37 PM
  3. Newbee Question - Jack stand position
    By 530iBall in forum 5 Series BMW
    Last Post: 05-30-2004, 11:40 AM
  4. newbee. bumper removal
    Last Post: 04-22-2004, 05:29 PM
