Well - maybe this will help.
Rotors: If you're really a freak, you can have the rotors cryogenically treated. They superfreeze 'em basically. Does something to metal crystals to enhance durablity. Racers are all over this. Not applicable to street use unless you want bragging rights.
Pads: Most pads have some sort of break in procedure that helps them mate to the rotors and set the glue compounds used in their manufacture. This is something you definately want to do when you install new pads. Look carefully in the box for an instruction sheet or try that manufactures web site. If all else fails, the web has generic procedures you can try. Most involve repeated partial stops with interval cooling sessions.
Other than that, I don't think there's too much more to consider.
Bellevue WA
86 Porsche 951 - Track Toy
