the M50 engine always has spark plugs with at least 2 gnd electrodes.
i'd use NGK BKR6EK, this spark plug is the same that BMW recommends and sells for the M50.
Hey everybody ,
I wonder if this plugs (bosch super 4):
http://www.boschautoparts.co.uk/pcPlug4.asp?c=2&d=1
will fit my 1994 BMW 520 with M50 engine (6 cyl).
It has 4 contacts. Do you guys know if it is of any use having 2 or 4 contacts instead of 1? Or is just hype?
Thanks.
don't waste your $$$ on platinums or other "super" plugs.
Go with stock plugs from ngk
^°^ ><((({º>°°
or bosch
Originally Posted by Sharkman540i
what if this super 4 and normal NGK cost the same? which would you suggest I buy?
stock NGK or Bosch
it's not about the $$$, it's the performance
^°^ ><((({º>°°
What about those denso iridums?
www.KaRealtySF.com
So you say NGK performs better than Bosch super 4? "Super 4" sounds a lot better than "stock NGK"Originally Posted by Sharkman540i
What is your opinion guys, which will perform better? They cost the same (or nearly the same).
NGK's...
www.KaRealtySF.com
