Results 1 to 10 of 19
Thread: Ok, im stupid - euro ellips
    Bay Area, CA
    Default Ok, im stupid - euro ellips
    So, I bought some euro ellipsoids that I thought were a good deal. But you know what. I just remembered, I need to rewire my headlights with h1 connections!
    Anybody have a clue how I can change my stock 9006's to h1's? I can't find any of the links =x.
    www.KaRealtySF.com
    Sep 2005
    If you have 4 female spade connectors and some heat shrink you can change them easy, the factory wires are held buy a clip in the end of the plugs ( 9006 ) on the low beams, just pop off the clip take out the 2 wires and cut them or dont take them apart at all and cut them about 3 inches from the plug ( so you can re attach them later if you want ) and just put on the 2 female spade ( blue spades 16 gauge ) connectors .
    Hope this helps
    Wellington,New Zealand
    one of those wires goes to the bulb itself and the other to a spade connector on the housing the bulb clips into
    here you go
    http://www.realoem.com/bmw/showparts...43&hg=61&fg=15
    I went through this and none of these are a perfect connector because of the design. I spent a while looking through here, maybe something will work for the headlights, didnt get it exact for the elipsoid fogs.
    Feb 2005
    Richmond, TX
    I bought new connectors and the wire leads from the dealer. The leads snap into the connectors and then you splice them into your current wires.
    1988 M3 - Track rat
    1989 325iC
    1995 530iM
    2000 323iT - UUC BBK, PSS9 Coilovers
    2005 GMC HD Crew
    Default I wish it was that easy
    when I did the fogs, I had to special order 3 different part numbers and guess what would fit...none were perfect.
    Quote Originally Posted by brodee
    Bay Area, CA
    Thanks for the help guys. I finally found that website with those p'n. Thanks scDavid for that.
    http://www.m3bmw.com/e34/
    Does it look right?
    LOW BEAMS: (Need Two H1 Bulbs)
    Low Beam Caps: 63-12-1-378-333, 2 needed- ($18.50/ each)
    Yellow Connector Terminal Plugs: 61-13-1-378-419, 2 needed- ($1.45/ each)
    Wiring Cables: 61-13-0-007-445, 4 needed- ($3.00/ each)
    HIGH BEAMS: (Need Two H1 Bulbs)
    High Beam Caps: 63-12-1-378-367, 2 needed- ($18.50/ each)
    White Terminal Plug Connectors: 61-13-1-378-417, 2 needed- ($1.45/ each)
    CITY LIGHT SOCKETS: (AKA "E.T. Fingers"
    City Light Socket Housing: 63-12-1-378-334, 2 needed- ($9.90/ each)
    Grey Terminal Plug Connector: 61-13-1-378-402, 2 needed- ($1.45/ each)
    Wiring Cables 61-13-0-007-441, 4 needed- ($3.00/ each)
    Minus the housings -which should have came with the euro ellips.
    Brodee- did you order your euro ellips from that place already?
    www.KaRealtySF.com
    Feb 2005
    Richmond, TX
    Quote Originally Posted by liquidtiger720
    Not yet, have to wait until next week. Yours didn't come with the caps that go over the bulb??
    1988 M3 - Track rat
    1989 325iC
    1995 530iM
    2005 GMC HD Crew
    Bay Area, CA
    Haven't recieved them yet, they should be here on tuesday.
    www.KaRealtySF.com
    Apr 2004
    Reston Va
    Thats what I did too. hooked up the city lights too- JT
    Johntee540
    1994 540/6 Black - Tan - 199k
  1. Smoked Hella euro ellips on ebay.
    By Felixdacat in forum 5 Series BMW
    Last Post: 12-19-2006, 09:12 AM
  2. I'm stupid...
    By TheEndIsNear in forum 5 Series BMW
    Last Post: 06-29-2006, 07:48 AM
  3. stupid etk
    Last Post: 03-27-2004, 05:57 PM
  4. E34 Euro Hella Ellips. GP
    By BMWE34M5 in forum 5 Series BMW
    Last Post: 03-18-2004, 10:22 AM
