Thermostats are funny fellas. I think a good rule when putting a motor back together is to put it in a saucepan with a 100 degree thermometer, chk it fully opens at the rated temp so you can count it out of any operational problems you encounter afterwards.
Kriss, one word of warning though- boiling a thermostat can wreck it- some have wax or a checmical substance inside them that can come out if they boil. Not sure about ours though.... perhaps these are old ones (I've never boiled one yet as it only takes a minute or two) and I am usually due for a cup of tea by then... GP
Kriss- be sure the air does not get back in when sitting overnight. After she pressurises over the next few drives, be sure to shut her off and check the bleeder for air. If you keep finding some, it indicates a small leak. Its a good check, helps you be sure its done right. GP
EDIT: And always drill a 2mm hole thru the top of the outer ring. Bleeding is a guessing game without doing so...
Hopefully, your heater core isn't the cause of coolant loss. That was my case, so I bypassed it till I can get the time to fix it or the money to have someone else do it.Originally Posted by BigKriss
