Results 1 to 10 of 11
Thread: Bosch Had Me Cursing
    Long Beach, CA
    Default Bosch Had Me Cursing
    I pulled the new Bosch spark plug wire set I just bought out of the box to make sure it looked like the right part today. Things looked good until I saw the 7th wire which goes to the Ignition Coil (I think). At that point I was sure I had gotten the wrong wire set.
    I went to a couple of parts sites with pictures to compare to what I had in front of me. It seems they put that wire into the tube backwards. Has anyone else had this experience?
    Bethlehem, PA
    You mean the open end of the coil cover was on the loom side of the wire? Yipes. That's a pretty flagrant error. The picture you posted is the way it should be. guess you're gonna have to send it back. There's no way you're going to fix that without damaging something.
    turn it around.
    Long Beach, CA
    Quote Originally Posted by SRR2
    I don't think I've got to send it back. You actually can just buy the tube. It opens up and you can turn the wire around.
    Long Beach, CA
    Default Here's the way they came
    Here's a picture of the way the plug wires came:
    Honolulu
    Default Looks like it's just
    backwards in the loom.
    pull it out and re thread it back in the right way.
    Use the one on your car as a guide
    push the boot on and then the cover over it in the right direction...they will turn in the cover so you can fix er up.
    Long Beach, CA
    What? I can just open the loom, right?
    baton rouge, loserana
    yep it opens right up, little clips hold it together the bitch is if it has a piece of heat shrink holding the front end tight you will need to cut it as it's too small to fit the wire end through, i usually just run a zip tie around it, it's just a back up for the clips so they don't get broken if the wire set gets rough handled
    Quote Originally Posted by uscharalph
    Long Beach, CA
    Sounds Good!
  1. M30 Coolant Change (It's cursing time again...)
    By Mitch90535im in forum 5 Series BMW
    Last Post: 11-07-2007, 08:18 PM
  2. Bosch Super Plus?
    Last Post: 06-20-2007, 08:48 PM
  3. Has anyone tuned the bosch dme: 402/403/405?
    By Anton CH. in forum 5 Series BMW
    Last Post: 12-04-2005, 01:04 PM
  4. Bosch injectors
    By The Don Man in forum 5 Series BMW
    Last Post: 10-20-2005, 06:03 PM
  5. Bosch or Bremi?
    By granit_silber in forum 5 Series BMW
    Last Post: 08-03-2005, 10:21 PM
