Michael Jackson has another dude charging abuse.
Originally Posted by Martin in Bellevue
320i mounts are an upgrade yes, the UUC ones are an upgrade from those. the 320i mounts require modification to work.
Buy a handful of turnbuckles and lock down the engine and trans.
Worked great on my Rotary Mazdas....no more broken motor mounts and all the torque and vibration goes right to the frame for that real go kart ride.
IMO, this is a useful upgrade on higher horsepower cars where there is going to be considerable lateral movement in the drivetrain OR cars that are going to be driven HARD(i.e. track cars).
I wouldnt bother on my E34, not worth it... However, I do have them on my E30.
Bob Cooper
1992 525i
1989 325i/S50
Originally Posted by Jon K
oh no i know they will help quite a lot, its just that
it was worded funny!
uuc of course does sell some great stuff so 200% might even be accurate
it was just the way they said it heheh made my chuckle a bit
Originally Posted by MTRIPLE
You would if it were supercharged.
Correct, I had them on my Supercharged M3 and they were a great mod, especially a safeguard against the infamous "money shift" on the M3's. As mentioned, I also have them on my E30 track car because it gets worked pretty hard.Originally Posted by Jon K
I didnt realize your car was supercharged... details?
Bob Cooper
1992 525i
1989 325i/S50
As I already have the urethane subframe reinforcementplates, my only real weak link is motor mounts right now. I will probably go with a soft urethane or poly mount.
It's a custom ASA-based setup. I JUST received my 150mm pulley in the mail today from germany! Very pysched.
Sounds hot, Vortech based? I had a modified Dinan setup on my M3 with custom tuning by AA, 6 inch crank pulley/8 rib belt setup from RMS, and water/methanol injection. Car made 322rwhp at 11psi...
Bob Cooper
1992 525i
1989 325i/S50
Not vortech based, its an ASA blower clutched, as used by Alpina. 320hp @ 11 psi is very low. RMS probably had something to do with that. 8 psi 3.0L's are making 315, 10 psi M3s are now making into the 380's - 400's
