Have you checked the LKM?
Also could be dying battery or alternator, bad gauge capacitors, or a combination of those.
Went to turn on the head lights as i was driving into a tunnel, and the guage cluster went dead and only both turn signal indicators glowed steady.
This lasted a few scary seconds, then everything came alive.
What could be going on ?
DanH
1989 535iA 254k Miles
1992 535iM 330k Miles
Add this to the list... It could be a poor/loose ground connections.
DanH
Lights all work fine, no flickering low beams..so I not sure about the LKM failing.
Battery is less than a year old.
Alternator seems to be charging, and the car runs all night without draining the battery.
Maybe a relay?
I tend to agree with the relay theory, makes the most sence with them symptoms...maybe just a fluke.
Can you please tell me how?? I mean inspect. Test for sure.check the lkm anyway. its very quick and easy to inspect.
There are too many people here on the board which are change-ingeniers, but not engineers.
I agree, the slightest mention of anything regards light issues and they ignore the other related problems and say ITS THE LKM!!Originally Posted by shogun
id go with a short somewhere
shogun the lkm can have intermittent failure as you know.I had failure of my low beam only a couple of times.I took my car to the local auto electrician with Brunos write up.He said he could not replicate the low beam failure,and remelted the solder anyway.I have not a had a problem since.......
this is a good example of ignoring the facts and giving a reply...yes the LKM can have issues but you are ignoring the fact that the turn indicators glowed slightly...the turn indicators dont go through the LKMOriginally Posted by Paul in NZ
