Just recieved a set of lemforder control arms and thrust arms with M5 bushings from BMA. $130 a piece for the TA's with m5 bushings in. Those bushings sure are.. small looking. If i had a digital camera i'd post a pic- but theres barely any rubber, just three little rubber spokes radiating out from the center.
Sometime early next week i'll try and put them in. I'm going to do the whole remove-the-strut-and-spring deal so the steering knucle is sitting there exposed just waiting to have those balljoints pounded out of it.
Besides torquing under load, any tips that haven't been mentioned 800,000 times?
I take the wheel off, take the brake caliper off, undo the 3 nuts at the top of the strut tower, take the 3(?) bolts off the bottom and just pull the thing off, right? Should i remove the steering tie rod as well, or will pounding on the ball joints with it attached not damage anything?
