Results 1 to 10 of 10
Thread: OK to use Copper Tee to Bypass Heater?
    Long Beach, CA
    Default OK to use Copper Tee to Bypass Heater?
    Does anyone know if a copper tee would cause any problems with the cooling system. I bought a copper tee to use to bypass the Heater Core (Leak). If there's a problem with copper, I'll find a plastic one at an auto parts store. I was going to connect hoses 2 & 3 to the horizontal on the tee and hose 1 to the vertical on the tee.
    Apr 2004
    Copper and aluminum in an electrolyte, which the coolant is as it ages and becomes acidic, is not a good thing. e30 had bad result from copper or brass fitting in ac evaporator. Plastic should be easy to find.
    as a temporary measure copper will be fine, dont leave it there forever though.
    Feb 2005
    Penang, Malaysia
    i'm sorry to re-activate an old thread - i could not find info after much searching thru the archives.
    what size (in mm diameter) of tee would be right to do this bypass and what material is best?
    Quote Originally Posted by uscharalph
    Long Beach, CA
    Quote Originally Posted by ktteoh
    It's funny, that same copper tee is still in my car over a year ago. I'll see if i can find the receipt.
    O.C.
    speaking of coolant temp fixes.
    I used epoxy on my expansion tank for about a year and 2 months. I finally threw done 40 bills. This was when it was very hot in SD.
    Feb 2005
    Penang, Malaysia
    ralph, could you take a picture of the copper tee as installed - i want to know that i get the flow right - did you have to extend the hoses or is the existing ones have sufficient length?
    Mar 2004
    So Cal
    I know you can use the existing hoses. I'm Ralph's brother and I did the install. I remember just having to loosen some of the clamps to adjust the hoses just right. Hopefully Ralph will post a pic.
    Greg Mendoza
    Long Beach, CA
    Quote Originally Posted by Mendozart
    Here's the pics I finally took. I goofed up on the last one showing the rubber plugs keeping things from getting inside the heater core. Maybe tommorrow.
    Feb 2005
    Penang, Malaysia
    ralph, thanks for the pictures. can you tell me the diameter of the tee joint used - maybe put a small ruler against the one in your car?
    sincerely appreciate your help & trouble you took to help me.
  1. A/T Pan Fill Copper Washer Size is... what?
    By RobPatt in forum 5 Series BMW
    Last Post: 07-22-2008, 09:53 AM
  2. Heater Core Bypass - 89 535i E34 model
    Last Post: 07-20-2008, 06:58 PM
  3. copper ring that holds headlight bulb in
    By bbig119 in forum 5 Series BMW
    Last Post: 04-05-2007, 07:38 AM
  4. E34 heater core bypass
    By ktteoh in forum 5 Series BMW
    Last Post: 01-06-2007, 08:12 AM
  5. OT: Ford F-150 heater core bypass
    By bimmerd00d in forum 5 Series BMW
    Last Post: 01-05-2005, 12:00 PM
