Originally Posted by
Robert K
I can't remember where I read it, but one premium car manufacturer was asked why they didn't use multiple pot brake calipers. They said their single pot brake calipers weren't the limiting factor...it was the tires. I suppose if you're going to race your car all the time, then bigger brakes are probably not a bad investment. And if you're truly running hard, you might want to look into brake ducting to dissipate the heat, which is the primary job of the braking system anyway. But, if you're just doing regular driving, I think the standard E34 brakes are more than up to the task. Think of it this way...if you can engage ABS in normal emergency stops or hard braking maneuvers, then you're brakes are actually stronger than you need. As mentioned above, the tires are the weak link, which is why the ABS is engaging. If you had stickier tires, THEN you might see the need for the increased brake components.
To me, the brakes on the E34 are one of its high points, and one of the reasons I own one. Not only do I look at my car as means of enjoyment, but I also look at it as something that may save my life. The E34 has an excellent crash structure, great handling, and great brakes. If the last two can't get you out of a jam, you may have to depend on the structure to protect you. But being able to stop quickly is one thing an E34 does well.
Just my $.02.
Grace and peace,
Robert K
1991 535i
