Results 1 to 5 of 5
Thread: Strange Noises Between 2,300 - 2,800 RPM
    Default Please Help-Strange Noises Between 2,300 - 2,800 RPM
    Model (520i SE - E34 1993) Can runs quite & smooth, but when accelarating 'Only' between 2,300 - 2,800 RPM getting strange grumpling noises from rear of car, regardless of in 1st, 2nd, 3rd, 4th or 5th gear?
    New exhaust was fitted recently (So That Is Ruled Out)?
    When going over (Holes & Bumps) on road - No Problems - That would suggest suspesion is OK?
    Whilst Stopped - Engine Vibrates Slightly When Taken Up To (2,300 - 2,800 RPM) but not as much noise as when under (Load - Driving).
    Could this be an engine problem, but just hearing it from the 'Exhaust Output'?
    Can drive at 120MPH and car is smooth & quite.
    Thanks everyone in advance
    Sep 2004
    Tasmania
    Even though it sounds like it is coming from the back of the car it may be a worn cam belt.
    Jul 2005
    Cologne, Germany
    what's a cam belt? timing belt?
    greets from Germany,
    Kai
    A BMW is a black car with most rights in road traffic.
    Ireland
    93 520i has the M50 engine whiich uses a cam/timing chain not a belt . The symptoms you describe sound like it could be a failing vanos unit which a 93 520i would have also.
    check the exhaust so that it isnt real close to rubbing something...also check the engine and trans mounts which can cause the system to hang where things can touch also.
  1. glove box noises.....?
    By LAXman2205 in forum 5 Series BMW
    Last Post: 05-10-2006, 01:14 PM
  2. funny noises
    By BMWgeek in forum 5 Series BMW
    Last Post: 11-05-2005, 05:54 PM
  3. New Tires - New noises
    By Drooby in forum 5 Series BMW
    Last Post: 09-22-2004, 04:03 PM
  4. front end noises
    Last Post: 05-18-2004, 03:38 PM
