Making good progress in replacing flex fisk and center bearing. Driveshaft is out and nut connecting the two haves has been removed.
The two halves will not separate. It appears that the spline is stuck ( after 14+ years). Have tried banging lightly on the front of the driveshaft but I'm worried about damaging the driveshaft or knocking it out of balance.
any suggestions???
Thanks for older posts, they have help greatly to this point. I'm almost these if I can just get the new center bearing on.
One other questions. What type of grease should I use to repack the constant velocity joint at the rear of the driveshaft??
Thanks Mike Feeney
