Results 1 to 10 of 13
Thread: CAm lobe wear. How much is too much????
    Apr 2004
    Default CAm lobe wear. How much is too much????
    Cam lobe wear. How much is too much???
    1) If it is your current 535a?
    2) If it is on a head that you are buying to replace head with worn cam lobes?
    you can put your old cam in the new head, shouldnt be that hard.
    95 E34 530I V2.34
    Why not just get one of the aftermarket performance ones? I think it was Jeff N who mentioned that Ireland (?) has one for < $200 (big ?).
    best, whit
    shrick cams? between a cam and a chip things will be happening quick! On my V8 the cams dont turn on till after 4k so I dont think I would gain much...probably why they arent available.
    95 E34 530I V2.34
    Aug 2004
    Netherlands
    Itīs easy to see when can wear is too much, grooves on the " chrome" center part of the lobe indicate clearly that the cam is worn. If you want to upgrade to a fast road cam and a chip, the M30 will be a blast , especially with the kick down function. Do always buy a cam kit including stronger/stiffer springs.
    Aug 2004
    Netherlands
    Fast cams for the M60.....
    They are available from Bilas tuning in Germany, a very known and respected tuner in Europe. They don' t come cheap though. Take a look for youselves.
    www.bilas.de
    "CAm lobe wear. How much is too much???? "
    well i've gotten in 190e mercedes motors that were so worn the cam wouldn't open the valves anymore, i hate that turd motor
    Mar 2004
    Brisbane, Australia
    couldn't put it better myself!
    we have dubed the 190e the mercedes tercel
    Quote Originally Posted by Rory535i
    Default Wow
    04.057.001 262 114 10,9 1,0 1.966,00 Set
    wonder what the stock specs are since they only have 1 profile.
    Quote Originally Posted by Jose
    www.bilas.de
    95 E34 530I V2.34
  1. Worn Camshaft Lobe at 200k miles
    Last Post: 11-05-2009, 12:02 PM
  2. M30 heavy wear #1 ex. cam lobe Lash cap help?
    Last Post: 03-10-2006, 07:32 PM
  3. M30 cam - only one lobe bad, others clean?
    Last Post: 02-11-2006, 11:20 AM
  4. The pitman arm - does it wear out?
    Last Post: 08-05-2005, 09:21 PM
  5. Odd tire wear
    By greghodg in forum 5 Series BMW
    Last Post: 02-28-2005, 05:19 PM
