Cam lobe wear. How much is too much???
1) If it is your current 535a?
2) If it is on a head that you are buying to replace head with worn cam lobes?
you can put your old cam in the new head, shouldnt be that hard.
Why not just get one of the aftermarket performance ones? I think it was Jeff N who mentioned that Ireland (?) has one for < $200 (big ?).
best, whit
shrick cams? between a cam and a chip things will be happening quick! On my V8 the cams dont turn on till after 4k so I dont think I would gain much...probably why they arent available.
Fast cams for the M60.....Originally Posted by 632 Regal
They are available from Bilas tuning in Germany, a very known and respected tuner in Europe. They don' t come cheap though. Take a look for youselves.
www.bilas.de
"CAm lobe wear. How much is too much???? "
well i've gotten in 190e mercedes motors that were so worn the cam wouldn't open the valves anymore, i hate that turd motor
couldn't put it better myself!Originally Posted by winfred
we have dubed the 190e the mercedes tercel
Originally Posted by Rory535i
04.057.001 262 114 10,9 1,0 1.966,00 Set
wonder what the stock specs are since they only have 1 profile.
Originally Posted by Jose
that sounds about right, bimmer cams generally run $400-500 each and you have 4 of them
