Results 1 to 9 of 9
Thread: Offset
    Apr 2005
    new zealand
    Default Offset
    Is a 13 offset wheel going to work on my E34
    Aug 2004
    Milwaukee, WI; Chicago, IL
    It should work, might need 5mm spacers.
    Sorry not too keen on wheels.
    1990 BMW 535i 5 speed - Black on Grey, LSD
    20mm is normal / standard. 13mm should be okay.
    Nov 2004
    Default what's the width of the wheel?
    Since all 5/6/7/8 series BMW wheels are interchangeable (except the E39)...the wheel offsets of the oe BMW wheels for these cars run between 11mm (or maybe 10mm) - 26mm. If you go to the online parts database and look up the wheels of any 5/6/7/8 series (except the e39)...you can see the varying offsets for the different wheels to verify what I've written.
    BMW online parts database: www.realoem.com/bmw
    And as its been written ad nauseum...the E39 has a 74.1mm wheel hub whereas all other 5/6/7/8 series BMWs have a 72.6mm hub...and hubcentric rings are required to mount E39 wheels to prevent wheel shimmy.
    Q
    95 525iT / 97 740iL
    Calgary AB Canada
    Quote Originally Posted by montsta56 nz
    I run 17 x 8.5 with ET13 - no problem.
    Anthony
    Anthony
    03/64 production
    Apr 2005
    new zealand
    Quote Originally Posted by Qsilver7
    width is 8.5
    Apr 2005
    new zealand
    Quote Originally Posted by Anthony (M5 in Calgary)
    Anthony
    Cool thanx for your help guys,
    you guys rock,,,
    Dec 2006
    UK
    Just to dig up this old thread, any opinions on 8x17 ET10 and 9x17 ET20 with 235/45/17's for the E34 ?
    Dec 2006
    Long Island
    front track will be wider, changing the geometry.
    if you are lowered it might bring the outer edge of the tire too close to the fender lip.
    235 on a 9" wheel is a stretch
    use 255/40/17 in the rear
  1. wheel offset Q, they all the same?
    Last Post: 05-24-2008, 02:31 PM
  2. 18mm offset on E34
    By baddoc in forum 5 Series BMW
    Last Post: 07-02-2006, 08:50 PM
  3. 45 offset bbs on e30 323i !!!!please help!!!!
    By rotorhead in forum 3 Series BMW
    Last Post: 02-22-2006, 07:30 PM
  4. need help on wheel offset e36
    By juan525i in forum 3 Series BMW
    Last Post: 09-28-2005, 02:50 AM
  5. 10mm offset?
    By Beez540 in forum 5 Series BMW
    Last Post: 03-21-2005, 10:01 PM
