Results 1 to 9 of 9
Thread: Problem Solved Finally!!!???
    Jan 2005
    Sicily
    Default Problem Solved Finally!!!???
    Thanks for everyones help and suggestions, my mysterious noise was the POWER STEERING PUMP. It appears the old self leveling removal wasnt plugged right it was causing the noise the whole time.
    Nov 2004
    Winston-Salem, NC
    Quote Originally Posted by e34it
    CONGRATS on finding the problem!!!
    -ashley
    Paper Gaskets Suck!
    Aug 2004
    hey man can you tell me exactrly what u did
    i think i have the same noice for over 2 weeks i get this noice at serten RPM and only when it gets hot
    Calgary AB Canada
    Default Good news
    This issue has been discussed on the M5 group. When you disable the SLS, the supply and return lines need to be connected together rather than plugged. This can be done either at the pump or at the rear of the car.
    If you plug the line the pump is driving into the plugged line creating high static pressure rather than allowing the fluid to simply circulate with no pressure.
    Anthony
    Anthony
    03/64 production
    Sweet! I knew it had to be simple after them clues you gave and mentioned self leveling removal.
    Jan 2005
    Sicily
    ve39, i dont think your car has self leveling so that wouldnt be the problem, check your lines, and your ps pump, bleed it if need be.
    Default it dont anymore!
    Aug 2004
    sorry explain lines and ps pump not good with english car terms
    Wellington,New Zealand
    power steering pump and the hoses that run to it and from it....
  1. Solved my E34 surging problem...
    By onZedge in forum 5 Series BMW
    Last Post: 09-01-2007, 10:44 PM
  2. Problem Solved!
    By cableface in forum 5 Series BMW
    Last Post: 06-18-2006, 08:35 AM
  3. Replies: 6
    Last Post: 05-05-2004, 12:19 AM
  4. Finally solved the Check Engine Light (1221 code)
    By Erick in forum 5 Series BMW
    Last Post: 05-04-2004, 09:01 PM
