Results 1 to 3 of 3
Thread: I'm about to check my center bearing and flex disc
    Default I'm about to check my center bearing and flex disc
    From Bruno's site.
    http://www.bmwe34.net/e34main/Mainte...terBearing.htm
    The problem is I only have two jack stands. Where should I use the jack stands to jack up the car? On the front or the rear of the car. I need to do this to lower the exhaust system.
    regards
    kristian
    Aug 2004
    Milwaukee, WI; Chicago, IL
    Although it's not the safest thing, when my flex disc was done we used jack stands to support the car and then further jacked the car up by putting boards underneath the jack... then use more boards as needed. We also only used jack stands at the front of the car.
    1990 BMW 535i 5 speed - Black on Grey, LSD
    Austin, TX
    Try and locate a set of ramps for the front. It doesn't need to be jacked up quite as much. The rear wheels will need to be elevated so you can remove the CV joint bolts, you will need to rotate the rear wheels to access all of them. If they're on the ground, you wont be able to spin the driveshaft around to get all of them out. 4 Jackstands isn't the greatest idea in the world to be honest, I like ramps much better myself.
  1. Flex disc and center bearing R & R........
    By JD525IA in forum 5 Series BMW
    Last Post: 12-06-2006, 11:27 AM
  2. Other Pieces When Doing Flex Disc?
    By DaCan23 in forum 5 Series BMW
    Last Post: 03-06-2006, 07:40 PM
  3. Replies: 16
    Last Post: 12-17-2005, 07:07 PM
  4. Flex disc or 2nd Gear
    By araine901 in forum 5 Series BMW
    Last Post: 07-31-2005, 10:32 PM
  5. Replacing flex disk & center bearing - Help!
    By byurko in forum 5 Series BMW
    Last Post: 05-16-2004, 10:27 PM
