Results 1 to 9 of 9
Thread: What ever happened for the group buy on the subframe bushing removal tool?
    Default What ever happened for the group buy on the subframe bushing removal tool?
    http://www.bimmer.info/forum/showthr...frame+bushings
    The thread's about 6 months old. I'd like to do mine.
    Default Maybe the tool isn't needed.
    erased due to slander
    wow. thats what I saw going to ask in my next post.
    there's some good writeups in the first link Martin.
    Gainesville, FL
    Yes, great link.. maybe i've figured out what to do with my engine mounts! (fill them with ploly!)
    Only thing about that writeup is, they say (or, maybe Bruno says) that it's not a good idea to lubricate that particular bushing going in.
    The jack being used to press it in is a good idea
    Don't you just wish you had a link setup instead, like the E38/E39?! (hehehe)
    best, whit
    Aug 2004
    Netherlands
    Why not make one yourself ? I used this info from a german site. It works absolutely great and fast. Two bushings in less than an hour...
    Apr 2004
    Only somewhat related, but I installed Bruno's rear subframe bushings two weeks ago: I was pleased with the improved steering response - more so because that was not the result I had expected. A great bang for the buck - and all done well within 1/2 hour.
    With 90K miles on the car, I didn't think the bushings were gone; however, thanks to Bruno, the overall result is a tighter car with more linear response.
    BTW, as a random thought after reading above link on the urethane stiffening of subframe replacement bushings - is it worth a try to do it 'in situ' with the installed bushings: ie., drop the bottom plates and inject the goo into the bushing from the bottom ( make a cake decorator style injector with a poly bag taped to a pipe stub). Stick a set of the 'Bruno' shims on top and bolt up. Might work - and save a nasty job for a better day ...
    Aug 2004
    Netherlands
    Default just a drawing to make the apparatus in question..
    The measurments are not correct though and in cm´s. This drawing is for a E30 although they could be almost the same size.
  1. subframe bushing tool on ebay
    Last Post: 01-07-2007, 04:56 PM
  2. Where to get (rent) a rear subframe bushing tool?
    By Jjcarr in forum 5 Series BMW
    Last Post: 08-29-2006, 10:04 PM
  3. Replies: 4
    Last Post: 09-24-2004, 09:39 PM
  4. Replies: 3
    Last Post: 09-02-2004, 12:05 PM
  5. Subframe bushing tool - I need one.
    By JoeS in forum 5 Series BMW
    Last Post: 07-23-2004, 06:29 AM
