Originally Posted by spoolinturbo
You have 9.0:1 compression I believe. You have mechanical lifters there is no hydraulic conversion available. Performance cams offered by schrick and dinan i believe, many people here just get a regrind. timing chain needs tensioners SOMETIMES but never usually a replacement. the crank i think is cast but it could be forged not sure. the connecting rods are adequate. if you want lower compression headgaskets contact VAC Motorsports.
