Results 1 to 2 of 2
Thread: Oil Pressure Sensor location on M20
    Laplace, LA
    Default Oil Pressure Sensor location on M20
    So I got the Oil Pressure Sensor message and gong when I turned off my car yesterday. I opened the Oil filler cap and got sprayed so I know I have oil pressure. I searched the archives and found that my problem may be a bad oil pressure sensor. Where is the oil pressure sensor on the M20 (1989 525i)? Can I get the sensor anywhere other than the stealer? Thanks in advance.
    BMWCCA Member #330940
    Bayou Chapter, Louisiana
    Aug 2004
    Netherlands
    just above the oil pan on the right hand side of your engine. It' s very accesible. Use a 24 mm spanner to remove it. It will not be too expensive from the dealer at all. 20 quid should do it.
  1. oil pressure sensor location
    By rockin1978TA in forum 5 Series BMW
    Last Post: 03-06-2009, 05:28 PM
  2. fuel pressure test location
    By ahlem in forum 5 Series BMW
    Last Post: 04-09-2008, 10:35 AM
  3. 325I Transmission pressure regulator location
    By night_ranger in forum 3 Series BMW
    Last Post: 05-31-2007, 12:32 AM
  4. Location of knock sensor #2/540
    By Dr. Frank in forum 5 Series BMW
    Last Post: 03-16-2007, 07:42 PM
  5. 1994 325 a/c low pressure port location?
    By larry325 in forum 3 Series BMW
    Last Post: 06-27-2006, 04:12 PM
