Results 1 to 3 of 3
Thread: Waterpump questions
    Default Waterpump questions
    I'm thinking my the bearings on my water pump are gone. I'm looking through ETK at the water pump for the M30.
    http://www.realoem.com/bmw/showparts...98&hg=11&fg=35
    It lists item 4 as the "water pump bearing". Is replacing the bearing a DIY job, or should I just a buy a new pump?
    While I'm there I'm going to replace the hoses
    http://www.realoem.com/bmw/showparts...87&hg=11&fg=35
    ETK lists items 1, 2, and 3 and the three main hoses. Should I replace anything else while I'm here, maybe a new thermostat. Of course all items will be bought through BMA.
    Regards
    Kristian
    Apr 2005
    Lancaster, PA
    Quote Originally Posted by BigKriss
    Regards
    Kristian
    Just buy a new waterpump, don't try replacing bearings. It'll be a waste of time, since a new waterpump is super cheap from pretty much anywhere - autohausaz.com, bma, etc.
    I replaced hoses #1,2, 3, and 6. That's a good $130 in hoses though... Anyways, replace the thermostat (i didn't since mine was fine, but I should've). Make sure your fan clutch is good too - but that's easy to replace later w/out having to drain coolant.
    I'd say you have a good idea of what to replace while you're in there. Last I WOULD replace all 3 belts. Cheap and easy.
    thanks
  1. Waterpump leaking..
    By Bo525i in forum 5 Series BMW
    Last Post: 01-06-2010, 12:43 PM
  2. laso m30 waterpump question
    Last Post: 05-16-2007, 08:07 AM
  3. Where do the waterpump fragments go?
    By scoop2004 in forum 5 Series BMW
    Last Post: 10-12-2006, 12:10 PM
  4. Waterpump pully tool?
    Last Post: 07-13-2004, 04:54 PM
