Results 1 to 5 of 5
Thread: 540i/a running rough!!! please help!!!
    SCHUYLKILL COUNTY, PA.
    Default 540i/a running rough!!! please help!!!
    my 540i/a is running rough yet. changed o2 sensors, tested mass air flow sensors, good compression, new plugs, cleaned & tested injectors. my mechanic went over anything he could think of. he thinks that the problem could be the torque converteris out of balance. it idles a little rough, gets worse around 1200-1400, & then smooths out around 2500. it does this in park or drive or reverse. any help could be usefull.
    thanks
    tim s.
    1995 540i/a
    1987 325e
    Mmm... sound like he missed intake manifold gasket and ICV valve.
    Default tech. tested both, no problems found there!!!
    thanks for the suggestion!!!
    tim s.
    Toronto
    Default Get an engine leak test done!!
    Quote Originally Posted by tim s
    thanks
    tim s.
    1995 540i/a
    1987 325e
    you mean a leak down test. my 540i/a has an alusil block (m60b40 1 745 872).
    thanks
  1. running rough
    By edward in forum 5 Series BMW
    Last Post: 05-16-2009, 10:30 PM
  2. rough running
    By jippijak in forum 5 Series BMW
    Last Post: 02-26-2006, 04:46 PM
  3. help, 540i/a still running rough
    Last Post: 03-30-2004, 01:19 PM
  4. 540i/a running rough continue's
    By tim s in forum Engine & Drivetrain
    Last Post: 02-27-2004, 09:22 AM
  5. Please Help!!! 540i/a running rough
    Last Post: 02-19-2004, 04:12 PM
