Is there a special tool or some trick to turn the engine for valve adjustments in Auto trans 535?
Buy two Vice-grip type pipe chain wrenches. (The ones with what looks like a bike chain to wrap and lock around a pipe.)
Take the bike chain off of one and added it to the other.
Now you have a pipe chain wrench that will wrap around the harmonic balancer and allow you to turn, or lock the crank as needed.
I made one years ago and it comes in handy every time I do a timing belt or adjust the valves.
You could also to the electric starter bump. But I always miss my mark and end up turning the crank by hand any way.
Pull the plugs - do the starter blip - I watch the tech do it at the shop - takes like 15 minutes to adjust valves on one of thse cars.
Derek A.
90 535i 5 Speed - Style 5 17"
Grind down a wrench (32 mm I think?) to fit on the fan clutch nut. Works great.
Mike S.
1992 535iM black/black
1997 540iM white/gray
Retired: 89 535iA, 85 318i
<<Support your local autobahn, stay out of the left lane!>>
Gene...
http://www.nmia.com/~dgnrg/page_5.htm
Don't waste your time manually moving the crank. I've adjusted my valves about 5 times in the past two months (have to get them *just* right ), and the remote start is the quickest and easiest.
At first, I used two pieces of a heavy gauge coat hanger. Not adviseable. I've graduated to a set of wires with a 30a in line fuse. Works superbly. Don't waste your time cranking it by hand -- too much risk of nailing the radiator accidentally, and too freakin' painful on the back.
Best, whit
I also have an automatic 535i. When I adjust the valves, I remove all of the plugs to check the gaps. I leave them out while I adjust the valves. I literally reach down and turn the crank with my hand gripping the harmonic balancer. For me, it's much easier than bumping the starter. For one thing, you never know how much the starter is going to turn the engine over. If you do it by hand, you just watch the cam lobes of the cylinder you're going to adjust. When both lobe tips are pointed equally away from their corresponding rocker arms, you stop, adjust the valves, then manually crank it around to the next cylinder. Trust me, I've been using the method for years and to me, it's as easy as anything.
Grace and peace,
Robert K
1991 535i
I used to use a socket on the crankshaft nut. This was too tedious and usually got nicked/scratched when the socket slipped. Some have made there own little switched to pump the starter. I tried doing the same but couldn't find the right switched I needed although I had handy the proverbial "pill bottle" and wires... So I gave up on this and went to NAPA and purchased a remote starter switch for $12. Couldn't believe how embarrasingly easy and fast it was to do the valve adjustment. The switch fits ergonomically perfect in the hand so that you can bump the starter by very small increments. One of the best investments I've ever made.
What kind of pin/whatever do you use for plugging in to the "n" pin connector. I have a couple of remote starter switches. Used em for this application on 2002s.
I use a stripped wire...nothing hi-tech
Also, I like using the remote starter method because, after doing the valves, it allows me the opportunity to crank the sucker for a few seconds so I can watch the oil passages/make sure everything's flowing correctly.
best, whit
male pins 61 13 1 376 191 . From bmw they are .40 cents each. And i used a momentary spring loaded switch i had laying around , Its by far the easiest way for me to set the valves on bmw's, you just put the toe of each cam lobe 180 degrees away from the eccentric adjuster so that the eccentric is in the center of the cam lobe heel.
Originally Posted by Gene in NC
