I cant see the pictures
This four spoke E46 wheel came from a E34 330i. Since its airbag is dual stage firing, that is NOT compatible with E34 designs so it cannot work. However, the E34 airbag can be fitted with minor modifications!.
Cut polyurethane support for airbag in the wheel. Drill 4 holes near the spline to accomodate the slip-ring cable connector. When viola, it fits nicely. The diameter is also smaller than stock E34/95 wheel so it is nicer to use.
Pics here ->> http://www.cardomain.com/memberpage/824698/3
Great upgrade!.
What year is your E34? Seems as if all options for my 89 535iM are all worthless. I don't want to loose the airbag... no matter what causes an accident - IE a drunk driver... if my insurance says I have an airbag, drunk driver hits me, and i get seriously injured. Guess who won't be compensated becuase of removing the airbag?
Sigh...stupid 15.5" steering wheel!
Mine is a 95 touring. I think fitment for E34 changed from 91 or 92. My E34 89 sedan had a 22mm nut holding the wheel to the spline. It has no airbag.
The 95 had a 16mm nut holding the wheel to the spline. Spline fits perfectly to E46 wheels. I reused my airbag.
Regal, Pls show me how to post pic. The file is 136K and this board limits to 39K ?. Having trouble uploading..... Got pics of mod as well.
on your favorite site and link them to your post.
Originally Posted by emw525E34
Mine has the airbag though. It's a monster steering wheel (as you all know)Originally Posted by emw525E34
If the spline of the E46 wheel fits, you could do the mods , I have done. Let me check my Sparco Hub that I removed from my 89 E34 525. That fitment is the same as your 535, I am sure. I did not have time for the comparision when I did the mod. Darn part was in the same tools cabinet I was working from!.
Major difference is bolt (in 95 wheel) compared to 22mm nut in 89 E34. But it seems spline grooves looks uncannily similar. Will update you tomm on this.
Sounds great. I'm actually pretty despirate to change this steering wheel out but keeping the air bag. Even if it doesn't do a damn thing, I just need it to deploy in case I DO have an accident bad enough. I've considered the airbag wheel from the later E30's (318is and 325ic), but they are still 15"...not much different than my 15.5".Originally Posted by emw525E34
A friend has found it on German fleabay and got so excited about it and bought it for 80 EURO= abt. $ 100. Told him that his car has airbag. He did not notice the difference.
So I get it now from him at same price, as I do not have an airbag in my car.
And then I also was the winner in a bid in Germany for a set of modules out of a E32 740 i from 11/92, LKM-L, GM (the new one with the features) and the RM for 40 EURO= about $ 50/full set.
Was my lucky day yesterday
ok, i'm confused about this steeringwheel business. can you not use a non air-bag wheel in a car that came with an airbag? does it attach so substancially different that it can't be fitted?
