Pls check the link below if your bimmer is on the "safety recall"...
http://www-odi.nhtsa.dot.gov/cars/pr...callsearch.cfm
Make : BMW Model : 540I Year : 1995
Manufacturer : BAYERISCHE MOTOREN WERKE
NHTSA CAMPAIGN ID Number : 97V131000 Recall Date : AUG 14, 1997
Component: VEHICLE SPEED CONTROL
Potential Number Of Units Affected : 410000
Summary:
THE CRUISE CONTROL AND THROTTLE CABLES ARE ATTACHED TO THE SAME THROTTLE VALVE ACTUATING LEVER AT THE THROTTLE HOUSING. IT IS POSSIBLE THAT THE PLASTIC BUSHING ON EITHER CABLE COULD BREAK DUE TO ENVIRONMENTAL INFLUENCES COUPLED WITH VIBRATION. IF THE BUSHING BREAKS, THE OUTER CABLE HOUSING CAN SEPARATE FROM THE BUSHING. IN THIS CASE, DURING APPLICATION OF THE THROTTLE PEDAL WITHOUT CRUISE CONTROL BEING ENGAGED, THE OUTER TUBE COULD CATCH ON THE EDGE OF THE BROKEN BUSHING.
Consequence:
THIS COULD CAUSE THE THROTTLE VALVE TO REMAIN PARTIALLY OPEN. IT HIS WERE TO OCCUR, THE CAR MIGHT NOT DECELERATE AS EXPECTED INCREASING THE RISK OF A VEHICLE CRASH.
Remedy:
DEALERS WILL INSTALL A SPRING STEEL CLIP ON THE OUTER TUBE OF EACH CABLE IN THE AREA OF THE ADJUSTING SCREW AND PLASTIC BUSHING. THE CLIP IS DESIGNED TO PREVENT THE OUTER TUBE FROM DISLODGING FROM THE BUSHING.
Notes:
OWNER NOTIFICATION IS EXPECTED TO BEGIN BY THE END OF OCTOBER 1997. OWNERS WHO TAKE THEIR VEHICLES TO AN AUTHORIZED DEALER ON AN AGREED UPON SERVICE DATE AND DO NOT RECEIVE THE FREE REMEDY WITHIN A REASONABLE TIME SHOULD CONTACT BMW AT 1-800-831-1117. ALSO CONTACT THE NATIONAL HIGHWAY TRAFFIC SAFETY ADMINISTRATION'S AUTO SAFETY HOTLINE AT 1-800-424-9393.
Yeah, my '95 540i is on the list. Will open the engine cover & check it tomorrow... (If it doesn't have these 2 clips, I need to hack the BMW stealer in my hood for a free part.)
Happy bimmering,
CC1
'95 BMW-540i/Auto (ZF-5HP30)...NO reverse
"Original" Nikasil block (+ Fristo Lays Chip)
87+ K Miles
