1999 Z3 with a Blaupunkt Business head and Pioneer Changer. Battery was disconnected and needed to enter code on head unit. Head unit works fine now, but does not recognize changer. Changer has power. When the magazine is inserted it cycles through each CD starting with 6 and stops when 1 is loaded. When I press the CD/Tape button it says "no tape" and will not go to CD.
If there are no bent pins, should I grease the connector?? Does something need to be reset? I did press and hold the button next to the magazine eject button on the changer.
Thanks.
