Results 1 to 2 of 2
Thread: Sway bar bushings
    Bethlehem, PA
    Default Sway bar bushings
    I suspect I finally found the source of the persistent 'clunk' in the front end of my iX. It looks like the bushings at both ends of the sway bar tie rods have fossilized. It also looks like they are a bear to replace, particularly those at the top of the struts. I confess, I was in a hurry and didn't spend a lot of time looking over the situation.
    Can anyone shed some light on replacing these?
    BTW, kudos to the BMW engineers for what has to be the easiest-to-replace O2 sensor in the history of automobiles. It was the original with 150000+ miles on it. Five minutes flat. And most of that was making sure the wiring was safely situated.
    Feb 2005
    brisbane
    its piss easy to change sway bar bushes,
    what do u need help with, are u getting rubber
    or poly's?
  1. Any tips for the sway bar bushings? I'm stuck
    Last Post: 03-10-2009, 05:35 PM
  2. Anyone replace sway bar bushings?
    Last Post: 08-25-2008, 10:27 AM
  3. Sway Bar again! Will an M5 sway bar fit a 540i?
    By leicesterboy15 in forum 5 Series BMW
    Last Post: 11-14-2007, 11:30 AM
  4. Anti-sway - No way
    By mjfeeney4 in forum 5 Series BMW
    Last Post: 09-13-2004, 07:05 AM
