Results 1 to 3 of 3
Thread: How to :: remove and change steering wheel (e34)
    T·O·R·O·N·T·O
    Default How to :: remove and change steering wheel (e34)
    Hopefully this thread will be a how-to change the steering wheel on the e34. I understand that the 89 is different from the rest. Anyone have pointers on how to do it? Changing from the stock 89 wheel to the MTech II. Never done it before, of course, so be gentle!
    Nov 2004
    Easy. Pry off Roundel with flat screwdriver. See the exposed 22mm nut. Remove this nut with socket wrench.
    Rock the wheel back and forth, remove it, Then remove the horn electrical plug.
    Put the new wheel back. Do not over tighten the 22mm nut!. Horn button.
    Enjoy the Mtech wheel!.
    If you have an airbag, read Bill R's writeup:
    http://www.bimmernut.com/~billr/imag...gAndBulbs.html
    It's all simple stuff. Just make sure you've got the right tools (or tools that'll work ) before you start.
    good luck!
    best, whit
  1. 1995 E34 525i, want to change steering wheel
    By LunatiC in forum 5 Series BMW
    Last Post: 01-21-2011, 07:59 AM
  2. How do you remove the steering lock?
    By Bimmer Nut Ed in forum 5 Series BMW
    Last Post: 07-01-2008, 08:05 PM
  3. Leather steering wheel change
    By Fred Tyler in forum 5 Series BMW
    Last Post: 04-25-2005, 12:46 AM
  4. Problem trying to remove steering wheel
    By SRR2 in forum 5 Series BMW
    Last Post: 04-16-2005, 03:43 PM
  5. How to remove a hamster wheel?
    By BennyM in forum 5 Series BMW
    Last Post: 07-28-2004, 03:44 AM
