new dog bones and no new hardware-OK?
What hardware? The bolts and nut? I put new dogbones on last year and reused the old bolts and nuts. I did use red locktight and torqued everything to about 90 plus/minus foot pounds. They were tight with no play or wiggle. BTW, the old dogbones would flex very easily. The change made the rear end seem a bit more stable around corners. Each time I replace a suspension component, the handling improves that much more. Just my experience
Originally Posted by
NielsGalan
or may they "wiggle", twist and turn around the bolts as the car rocks form side to side????
Jeff told me that they should stay in place, but I need a second opinion (no offence Jeff!).
Doctors? Do you concur?
