sounds like you should inspect your LKM, might need to solder some points. Info is on Brunos site.
1992 BMW 525i
Heres whats happening....
- low beams work OK.
- High beam will flash if I pull the switch toward me, but If I push it forward to switch to the high beams they do not go on.
- Fog lights will not go on at all.
- Dask lights indicating fog lights on or off do not light up.... there may be other lights on the dash not working but I am not sure.
Any Idea what the problem is???
THANK YOU
Don't be satisfied with only looking at it, remove it, check continuity, check spades cleanliness.
Javier
