Results 1 to 10 of 14
Thread: Rotors: Vented vs. Cross Drilled/Slotted
    Grosse Pointe, MI (Detroit suburb)
    Default Rotors: Vented vs. Cross Drilled/Slotted
    I need to get some new rotors for my '94 E34 and I am faced with a larger selection than I anticipated.
    I'm curious what kinds of experiences people have had with the "performance" rotors (cross drilled or slotted). And are they really that much better then the OEM vented rotors that came on the car. I know they look really cool but looks can be decieving.
    The mechanic I have recently started going too, who specializes in Bimmers, Audi's, Mercedes and VW's, says he doesn't think there is much point in me getting them and that they prefer to use the normal vented rotors in his shop.
    Your thoughts?
    Jan 2005
    Chicopee, MA
    There is not much difference in performance, unless you get the $3000 sports set. In my opinion it all comes down to brake pads. The other thing are prices, you can get some quality rotors off eBay which are as good as OEM. Drilled ones look really cool, and they are one of the reasons why I'm getting a set of new rims Also from what I've noticed drilled/slotted rotors seem to wear pads slightly quicker than regular ones. That is why I put ceramic pads on my ride, they last longer and there is way less dust.
    i haven't had any experience with them, but two popular choice are the ATE powerdisc and the Zimmerman crossed drilled. I assume the heat from the slotted rotors escape quicker.
    You have to be pushing your car hard for the brakes to fade. In racing applications I'd say they help sure, on normal street driving, I don't think so. I've also heard the crossdrilled rotors wear out the pads faster than normal rotors. You can add e34 540i brake ducts also to help cool the brakes.
    I'm going with the zimmerman cross drilled. There not that much more expensive than stock.
    Malaysia
    Quote Originally Posted by BigKriss
    I second the zimmerman cross drilled choice of rotors,i installed them with jurid brake pads,my driving is very demanding type,its been over a year and just recently i noticed that the pads got bit worn out.Never had any problems with that combination,and will continue to have the same set.
    jj
    I have heard a lot about EBC rotors that are dimpled and slotted and their "green stuff" and "red stuff" brake pads (green for street driving and red for racing). Have any of you guys heard much about these?
    http://www.ebcbrakes.com.au/
    i'm under the impression the reds are still street pads. I'm getting a pair of reds for the front soon. The yellows and blues are for racing.
    Mar 2004
    Brisbane, Australia
    Quote Originally Posted by Clay 94 530i
    These are very common in the UK. Anyone with a modified "hot hatch" seems to go for EBC discs and green stuff pads. They seem to work well on the smaller cars and I've heard nothing but good write ups about the green stuff pads. Not too sure about the rotors, they look a bit cheap to me and I don't know how they perform on the bigger cars as i've only seen them on smaller ones. They say that the red pads are more suited to track use as they are a hard compound. Brembo do good replacement drilled rotors or slotted ones. I'd be interested to hear how they perform on the E34's.
    Aug 2004
    Netherlands
    Drilled or slotted. Visually a great impact, killer in breaking performance when the right rotor is used. Don' t go cheap on these ones or you' ll be sorry very soon. Cheaper, inferior drilled rotors such as Zimmermann are known to be cracking on the edges 9 out of 10 times due to the inferior materials used. A original BMW rotor will out perform these discs with eyes closed. If you want optics and performance, for a reasonable price, do buy EBC as the guys suggested. These have the drilled/slotted optics but are not fully drilled through resulting in not cracking under any circumstances.The metal used is heat trated meaning the material is heated up to temperatures you will never reach whilst breaking thus no bent rotors will hunt you.
    We use thes on the track and sprint days too and are very pleased with braking, non fading and duarbillity. One thing, do not buy redstuff from ebc if your car has ABS. It will not funtion propperly as this pad is just too hard.
    Nov 2004
    Winston-Salem, NC
    Default my thoughts
    Unless your running your e34 on the track consistenly or shell out for racing quality equipment - drilled, slotted, smothered, covered, etc... brake rotors are a waste of money. If you want to upgrade your brakes and still be able to afford fuel, go with a set of 850i brakes (you'll need 16" rims min.)
    Most of the drilled rotors out there crack at the drill points and actually have less surface area contact with the pads. Which means they perform worst than their OEM counterparts. They are all show and no go.
    OEM rotors are stupid cheap (even from a dealer) and balanced not by adding weights but by shaving material from the rotor. Like I said, financially, it doesn't make sense to "bling" your rotors. If you want performance from your brakes, change the pad compound to something more aggressive (you'll buy rotors more often though).
    BUT if you have to do something, buy the slotted set. No issues with cracking and maybe even some benefit for evacuating exhaust gases.
    my 2 cents
    -ashley
    Paper Gaskets Suck!
    I have 9 years experience in cross-drilled and slotted rotors under normal street or heavy street driving. There are tremendous difference between cross/slotted and stock rotors under any braking condition. It is very evident. I used same pads going from cross-drilled to stock (because I was selling the car and didn't want to spend money for other people). The grab is weaker with stock rotor... feels like slight fading... doesn't have intense grab as cross/slotted rotors did.
    Now I use only slotted wherever I can. It is worth every penny especially in summertime where heat is intense. I always use MetalMaster with slotted or cross-drilled. Now I am experimenting with ceramic.
    I like the grab of metalmaster better than ceramic... ceramic feels more like regular pad but alot quieter than metalmaster under intense braking but with no fade. I think it is waste of time to use regular pads with slotted/cross rotors as most of you mentioned you can't feel any difference.
    As for between cross and slotted... you can't tell that much difference in performance... cross might be slightly better but it is difficult to tell. For the 7 years I had that cross-drilled... never did it ever cracked... It was Zimmerman made in Italy. Only caution is do not wash car when hot... cold water and super hot rotor is sure fire way to warp it... possibly crack it if you went from highway to car wash immediately... as in automated. Again... never in that 7 years did it ever cracked on me and I even had the rotor cut once... However, cutting a cross-drilled rotor is not advised... it warp as easily as any cut rotor.
  1. Cross Drilled Rotors - are they that much better?
    Last Post: 05-19-2008, 07:57 AM
  2. Cross drilled rotors on ebay...
    By HIe34 in forum 5 Series BMW
    Last Post: 05-17-2007, 10:22 AM
  3. cross drilled rotors
    By tnt525i in forum 5 Series BMW
    Last Post: 04-01-2006, 04:04 PM
  4. FS: Cadmium plated cross-drilled Brembo Rotors
    By kngpen in forum 5 Series BMW
    Last Post: 08-31-2004, 10:50 AM
  5. Is there left and right side for cross drilled rotors?
    Last Post: 06-06-2004, 06:27 PM
