Apart from better injector design (I recall something about a 'pintle' that is 'better' in the Mustang injectors) your fuel pulses will be adjusted to make the air/fuel mixture correct for emissions (14.7 a/f ratio).
So even if you get bigger / smaller injectors from stock, the Motronic will just open them shorter / longer, respectively, to make the amount of fuel injected match the amount of air.
If you're at redline and gulping gallons of air, you could argue that a higher rated FPR and larger injectors will allow you to fully utilize all that air whereas stock units would not. But at lower RPM's, theoretically, there should be no difference apart from better atomization from newer/cleaner injectors.
That said, I have the 19# Mustang injectors and a 3.5 bar FPR. I don't notice a difference, but mentally I *feel* more prepared!
Robin
72 Chevy K10
01 E39 M5
