Results 1 to 4 of 4
Thread: Lambda Control 1 Engine Code
    Aug 2004
    Default Lambda Control 1 Engine Code
    Hi,
    I changed my O2 sensor this moring because I had code 1221 flashing on the engine. Now the check engine flashed 1222 "Lambda Control 1".
    Can anyone tell me what could be wrong and how to fix it.
    Sharmila
    Default Can you post the make / model of the car?
    Quote Originally Posted by unhygenix
    Hi,
    Sharmila
    Robin
    72 Chevy K10
    01 E39 M5
    Aug 2004
    the car is a 1995 model 525i
    Sep 2006
    Newnan
    Rather than starting a new thread, il post here on this unanswered one. Same problem as OP. Except i also changed what was suspected as leaky fuel injectors. Put in some design 3 19lb'ers, swapped in new o2's and bam new code :1222 "Lambda control 1"
    The car still misses on occassion but does idle much better than it previously did. CEL goes away when accelerating and only comes back on random occasions durring idle, never when accelerating.
    Any tips? Im hoping this isnt leading to a faulty DME...
    *Production date is 08/1994
  1. code 1222 Lambda Control 1 what is wrong
    By cobb535 in forum 5 Series BMW
    Last Post: 03-10-2007, 09:33 PM
  2. 540 barely runs. Code 1222, "Lambda Control" ? Help!
    By STingray1100 in forum 5 Series BMW
    Last Post: 09-27-2006, 08:49 AM
  3. Code 1222 - Lambda Control
    Last Post: 12-04-2005, 04:09 PM
  4. 540 barely runs. Code 1222, "Lambda Control" ? Help!
    Last Post: 11-02-2005, 11:22 PM
