this would happen just after you got it back from the mechanic... Perhaps one of the connections to the alternator was affected or the battery connection up on the firewall.. If all of that checks out good then yes I would say its likely the alternator, but don't jump to any conclusions until you check it out. Also check things like the belt tension, if its too loose it may not charge under load at higher rpms
Originally Posted by ryan roopnarine
